- Joined
- Oct 27, 2022
- Messages
- 5
Hello all - I’m the 15-year owner of a 2007 Fit Sport (original engine & auto trans, 338,000 miles). I’m starting to sometimes hear a clunk when I’m parked (on level ground) and shift into reverse; also (less often) when shifting into drive, and occasionally during up/downshifts between 1st & 2nd. The noise is less frequent/loud when first driving, more noticeable after the car is hot. Last winter (Northeast U.S.), the trouble practically stopped altogether.
With the car’s age & high miles, I’m hoping to delay/avoid gambling on major repair work. Seeing some posts suggesting motor mounts might be the cause, I checked the engine while shifting. Going into reverse from park, the engine does pivot toward the front of the car (as if rotating around the axle line) - shifting back into park, it adjusts to its original position. The opposite happens shifting into drive; the engine pivots toward the rear of the car; righting itself when back in park. Regarding the trans, my service records show fluid drain/fill changes, but I don’t think any were machine “power flushes”. I changed the fluid at 331K, hoping this would help, with no change. Though noisier these days, the engine’s showing no performance trouble or burning oil; the car’s in good shape otherwise.
I’d like to keep the car as a backup/in-town driver as long as possible, but realize the engine & trans have well outlived typical service lives. I’m leery of making a costly trans repair, only to have the engine fail after that. I’d appreciate your advice; regarding what a shop should check/try before recommending a trans rebuild/replace, and how much you’d invest to repair an old (but still zippy) Fit like mine.
Thanks for reading,
Greg
Thanks for reading,
Greg
