1995 Chevy Lumina 3.1L with 160K. Body in great shape, engine runs smooth and quiet just as it did when I bought it at 50K. Upper and lower intake gaskets recently replaced. Now it needs a new engine mount (the rubber one in the middle under the motor), new tork struts on top and new valve cover gaskets. The rear one leaks slightly causing oil to leak down onto the rubber mount which degrades the rubber. Worth it to fix it? Got a bid for 850.00 which I know is right.
