- Joined
- Nov 29, 2009
- Messages
- 10,258
I was told that if you remove the water pump on an engine it drains out the entire block of coolant. My question is am I risking ruining the oring seal in the water pump but removing it and reinstalling it? My other thought is to buy a bunch of distilled water and then just drain it and fill it up with distilled water then run it and drain it again and then fill it up again with coolant so that way I get about a 50/50 mixture. I believe the coolant capacity for my truck is about 27 quarts.
