Removing Vinyl Decals from satin black paint
Central IA
Okay, this is technically not for a car, but an electric guitar. It has a satin black urethane finish on it and the previous owner (its a pawn shop buy) put a vinyl decal on it. I am looking for a way to remove it without buggering up the finish.
I was thinking maybe plastic razor blades and a hair dryer, but is there anything that would be spray on that might work better?
Thanks all. It was an obvious trekkie as it says "Resistance is Futile". I wouldn't have minded it so much if it was applied well and not gigantic.
WD40 is harmless to paint. A plastic blade may create a shiny spot, use the hair dryer and remove it then clean up the glue with the WD40.
Use a hair dryer GENTLY to warm up the sticker then peal it back slowly while keeping it warm. Do not use a heat gun as it would be really easy to get it too hot and burn/crinkle the finish, plus the core is wood and could warp with high heat. Use WD-40 to get the residue off. With satin black I would stay away from Goo-Gone or anything oily like peanut butter. That'll just gloss it up.
....and don't peel it up. Peel it forward at 45 degree angle.
Like this:
http://www.youtube.com/watch?v=clI78qfUqlg
FF about half-way through. I've followed this procedure for other decals, stickers, price tags on various items, and it works great. Go slow -- at a 45 degree angle.
Since it's a guitar, and flat paint, I too wouldn't use any chemicals. This may be a tough task, and it may be noticeable once removed.
Thanks one and all, and yes its a finish that is hard to clean. I lemon oiled the fretboard since it was dried out and the residue that got on it from my hands was a pain to get off.
