Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 3,794
I am replacing my propane water heater but have an issue with the gas line.
The gas line needs to be moved back by a few inches as well as up by half an inch to connect to the new heater.
The problem is that the 1/2" extension teeing off from the main gas line does not have a local valve to disconnect the propane, so replacing it requires purging propane out of the main line.
I will have to evacuate the propane from out outside regulator but do not know how to do this.
After turning off the propane tank, I presume I have to vent the propane to atmosphere, is there a procedure for this? Would I just remove the bolt on top of the regulator?
