remote desktop question
Mine was the same way and a brand new cable, I'm sure the reason I kept it was that I was going to try replacing the ends on it. I have all the stuff needed but last time I did that it's been awhile and I could tell that I was out of practice but when I worked in IT I got pretty good at making cables. I have plenty of other cables and they are cheap enough from Amazon that I've been upgrading to cat8. The backbone is still cat6 which is more than good enough for anything I'd ever need it for. I have mostly 2.5gb devices now with some 10gb.
But yes RDP is horrible for transferring files... small files is ok but that's about it.
I have nothing 40Gbit, so I'd not even considered CAT8 cables, now you have me curious about their wholesale price, lol. I'm only now looking at upgrading my LAN to 2.5Gbit, as all the connected gear is Gig-E, so the only real advantage will be the uplink speed at this time, but that will of course eventually change.
I've been trying to get my friend into 2.5 but it's not really that feasible when you're dealing with the commercial equipment. Most of the managed switches are still 1gb w/ 10gb uplinks. He's actually using a Cisco Poe switch that I got really for a spare, it's 48 ports w/ 4x sfp that's only gigabit, doesn't even have a use for Poe but it's what I had available that would work for him.
I was using Cisco switches in the basement but I'm using Trendnet now for the 2.5gb, I have a Qnap but it's very finicky with the compatibility of the sfp+ ports that I just gave up and swapped it out. I found Trendnet makes a switch that's cheaper that's gigabit but it also includes 2x 2.5 ports for an uplink and another device. Most devices are still only gigabit and it reminds me of those earlier switches that were 100mb but came with a gigabit uplink.
Is that old Cisco a 2960? LOL
I'm currently using a Meraki 8-port that's in the same boat, has 2x SFP's but they are only 1Gbit, so no point in using them. I'm currently looking at this guy:
UniFi Pro Max 24 PoE - Tech Specs (ui.com)
Which has 2x10Gbit SFP's and 2.5Ggbit RJ45 ports. Since I'm using a UDM for my DD firewall at present, no issue going SFP to SFP with a 10Gbit uplink.
Actually yes they are the c2960s and I have a few of them stacked together, including some that have 2x sfp+ that I had connected my servers using dac cables. When I worked in IT the manager loved Meraki AP's and was over the moon when Cisco purchased them. Those 2960's you can get for practically dirt cheap on eBay now, even less than what I paid for mine. I mentioned it to my friend they are down in the $30-$40 range now. He needs an L3 switch or at the very least maybe an L2 with some L3 features.
I mostly just use RDP to connect to the other systems so I can keep them updated as they are headless units without the monitor, mouse/keyboard, etc... one of them I have setup as a multiplayer gaming server that my friends can connect.
Yeah, I've had a LOT of those switches, were common pulls from healthcare facilities when they were doing a refresh. Usually the stacking ones with the stack modules and cables. Great switches, last forever.
I have a Cisco L3 switch here sitting on the shelf, but it's loud and power hungry (3560-X) so it's not in use and is a "just in case" spare.
Meraki has been a BIG success for Cisco, that was a very wise acquisition.
