relieving fuel press on '99 yota prerunner
SE
I looked up on google and found that it says pull the fuse or relay for the fuel pump but there is only the 'IGN 7.5 A' fuse in the fuse panel under the dash and then there is the fuse for in the engine relay box for the 'EFI'
I want to relieve the pressure because, duh, I don't want gas spuing in my face under the truck when I break the seal free from the steel line to the filter.
So does anyone know which fuse I could pull to shut power off to the fuel pump? Or is that fuse that says IGN 7.5 A the right one? Because then what I found it said was to start the truck with that certain fuse pulled with the gas cap off the filler neck. Hence no more pressure on the line.
thanks
is it in the same place as mine is the 3.4 liter engine?
and thanks for the feedback!
I don't know if this works too on toyotas, but you can pull the gas cap and that releives pressure on my chevys.
