- Joined
- Jan 6, 2005
- Messages
- 10,252
Maybe I'm just having a brain fart, but I would like to refill the 16oz squeeze bottle with fluid from the 32oz bottle, like the ones in the pic below. Is there an easy way?
Amazon sells a 500 mL syringe with a 28" tube with a 9mm OD.Could be done with a big syringe connected to tubing shoved into the side tube.
This is how I refill the little bottle of 2 cycle oil I use to measure small amounts.Squeeze bottle 1, fill the top portion for bottle 1 from bottle two. Release the squeeze hold on bottle 1 and tilt so the liquid can flow and be sucked thru the tube?
Worth a try. Not sure it would be all that easy/not messy, or even worth it.
x3. Fill the small chamber, squeeze the air out of the large chamber and tilt the bottle to allow the fluid to be sucked from the small chamber into the large one. Have some patience and you'll get it done. A better option would be to get the Sta-Bil bottle in post #7 or find another just like it, they are out there.This is how I refill the little bottle of 2 cycle oil I use to measure small amounts.
That's what I'm going to do.A better option would be to get the Sta-Bil bottle in post #7 or find another just like it, they are out there.
