Originally Posted By: Joe90_guy
I would say there's an argument for moving to a heavier, less volatile engine oil as your car ages.
As your bores and ring faces wear with age, the engine will need a thicker hydrodynamic film for the metal surfaces to ride on. The easiest way to do this is moving to a higher viscosity oil.
Also as the bores & rings wear, the engine will produce more blow-by which will directionally both dump more fuel into the oil and strip more of the light front-end out of the oil to be routed through the intake to be burnt. Moving to a thicker, but less volatile oil mitigates against this. A progression from 5W20 to 10W30 to 15W40 to 20W50 might make sense.
IMPORTANT DISCLAIMER
No American political figures (even the crazy ones likely to start WWIII) were harmed or otherwise ridiculed in the preparation of this post.
So you s start with the lightest grade oil(5w30 or 5w20) then about 75k, you start using High Mileage oils(same grade) Then 175k miles, you start going out of grade with a thicker oil(10W30 to 15W40 to 20W50 ) all this time you also increase longer OCI's
At that time you using 20w50, you should be at a million miles.
