Originally Posted By: Quest
Never heard of this (higher mileage-->shorter OCI).
There will be lots of arguments and counterarguments on this one if you seriously wants BITOGers to debate but frankly, I will only offer my own subject point here:
-so long as your engine is in-tune, well maintained and what not, IMHO OCI intervals shall not deviate much as the mileage goes up (again, unless you are suffering from valve sealing problems, valve stem seal leaks, sticky rings that lead to elevated oil consumption problems, stucked/clogged PCV valves, etc. which, 1/2 of these things are attributed to proper mechanical maintenance).
Q.
+1
However, I can see myself and many others doing a shorter OCI if the engine has racked up a lot of miles. Not because it needs it, but rather, it makes us feel better.
So I say to you. Whatever would make you feel better is the right choice for you.
