Redline SI-1 formula change?
GTA, Ontario, Canada
was there any formula change on SI-1? i just received my order of Redline SI-1, the label is different than the one i purchased few month ago. the new one does not mention "1 bottle treat up to 100 gallon" nor marking maintenance dose on the end of label anymore. the new one actually says to use 1 complete bottle for quick clean every 3000 miles. if anyone is interested, i will take some pictures of new and old bottle tomorrow.
Please post the pictures if you can...
Thanks...
I think they changed the label over a year ago, maybe the first bottle you got was the older version and the newer version has a silver label?
thanks! hopefully no formula change otherwise i had 12 bottle of water-down version of SI-1!!.
sorry i dont have camera for now to post the pictures yet. i read both bottles again carefully and both do not mentioned about 1 bottle treat 100 gallon, but the old bottle had a line saying using 3oz as maintenance dosage.
Why post a picture? Words are much more useful. Yellow is unreadable so I chose brown. The 100 gallon claim is right there plain as day. Even a razy 'merican like me found it. How did you miss it?
REFORMULATED FOR IMPROVED MILEAGE!
RED LINE SI-1 Complete Fuel System Cleaner is formulated with the most powerful, high-temperature detergents to improve mileage and power by cleaning intake values, fuel injectors, carburetors, and combustion chambers. Regular use will maintain lifetime intake cleanliness standards as required by Original Equipment Manufacturers.
DIRECTIONS:
Add entire bottle to fuel take for quick cleanup of fuel system. For best results, use one bottle at least every 3000 miles and add entire contents before filling tank.
This product is safe for repeated use in unleaded, reformulated, and oxygenated gasolines and will not harm oxygen sensors or catalytic converters.
DANGER: Combustible. Harmful or fatal if swallowed or inhaled. Contains volatile naptha [sic] hydrocarbons. If swallowed, do not induce vomiting. Call a physician immediately. Keep away from heat or flame. Avoid contact with eyes or skin.
KEEP OUT OF REACH OF CHILDREN
DOSIS RECOMENDADA:
Agregue una bottella de combustible para una limpieza completa y rápida de los inyectores de combustible y de las válvulas de entrada. Si lo utilza en forma regular, un botella cada 100 gallons de combustible le asegura la limpieza de las válvulas de entrada de por vida, cumpliendo con los estándares establecidos por las compañías fabricantes de equipamientos originales (OEMs).
