Originally Posted By: dissaver
couple questions, why would the addition of the redline suddenly make the problem so much worse, the maf does not come in contact with the fuel system
would the maf cause a cylinder 1 misfire?
and also, ive heard from numerous sources that attempting to clean the maf will usually kill it, is this not true?
MAF votes imply the problem getting worse with the addition of SI-1 is coincidence.
Cheap gas, no cleaners, and long periods of sitting can result in a surprisingly varnished fuel tank.
I've run 5 or 6 bottles of S1-1 (1 shock dose, rest maintenance doses) through my F150's fuel system with no issues. The truck has gotten periodic doses of Techron fuel system cleaner and top tier gas over its life though.
Cheap gas, no fuel system cleaner, and a long periods of sitting can give a surprisingly varnished fuel tank.
