I'm considering whether to use Heavy Shockproof in my noisy Torsen differential. I've already tried different 75W140 gear oils with no improvement in the noise, which just happens going around curves. Since the rear axle bearings are also lubricated by the same oil, I'm wondering if the Shockproof is going to be OK for the bearings as well as gears. Meaning, will it prevent bearing wear as well as regular gear oil?
