Redline Power Steering fld in Type F system?
By Detroit
I have three vehicles that take Type F transmission fluid in the power steering pump. I am thinking of running Redline in them next time I change the fluid. Redline power steering fluid is listed to fit nearly any application including Type F, Dexron, Mercon, etc. I always thought you didn't mess with a Type F system putting anything but Type F in them as Type F was not friction modified, whereas Dexron and others are. The Redline Racing ATF is Type F, but very thick (10 cSt) whereas their PS fluid is a bit under 7 cSt. I just wonder how Redline's one power steering fluid can fit all these varying applications and if anyone has used the Redline PS in a Type F steering pump, did it work out in the long run?
I have used Mercon in power steering systems that called for Type F for years with no problems. My fluid of choice is usually Mobil 1 ATF which meets Mercon specs.
I've put Mercon in both my 1988 Mustang and my 1996 Contour power steering with no problems.
I've heard that the factory fill on many cars with type F specified in the manual may actually have been Mercon...
