Redline D6 VOA
Got my Redline D6 sample back What you guys think ?
Looks like a similar add pack of what I've seen before. What is different is the oxidation value is higher than usual. I'd assume they are using some quality base oils in this Transmission fluid?
I used Red Line C+ on my 62TE @ 46k miles replacing the ATF4+ OE fluid. I am nearing 40K miles on that change. I am going to use Valvoline ATF4+ or Red Line again when I hit 45-50k miles on the existing Red Line. I felt no difference from the OE to the Red Line. I wouldn't hesitate to use the Red Line again as it is fairly cost competitive but I will check pricing on everything when the time comes.
Much depends on your budget, your ATF change intervals, and whether you think it's worth a boutique ATF.
HPL's GreenCC has the best components, to my knowledge, of any Boutique ATF.
That is saying a lot comming from you! I have always been super happy with everything Red Line makes that is not a motor oil. That said I can not ignore such glowing compliment or endorsement for HPL's ATF. GreenCC. I have not heard of it before but I am going there now to check it out!
I will keep them in mind when next I need ATF especially enough to make shipping worth while like a rebuild!
