Originally Posted By: A_Harman
Thank you all for your comments! I decided to extend the OCI on out to ~8k miles and do another UOA when I drain it. I have just used up the last of my 10-pack of prepaid Polaris sample bottles. When I reorder with them, I will include TAN in the analysis.
Since my Camaro doesn't have an oil cooler, I suspect that it's really heating up the oil during track days. I tried a mix of M1 0w40/5w30 HM last year and it oxidized, so I'm a bit leery of M1 0w40. Although to be fair, I haven't run it "neat" yet. It would be nice to go over to my local Meijer and buy it at $6.79/qt.
The oxidation with M1 doesn't surprise me, LSx engines make for hot oil on the track. I assume you don't have an oil temp gauge, but that you see 280*F+ on track, just like the 'Vette guys. If that's the case, I would think Redline is still the go-to oil, the only other street oil that handles high temperatures as well is Motul 300V, and it's even more expensive. You just have to accept that you're paying dearly for the heat resistance.
RT6 might do better than M1 0w40, UOAs seem to indicate it's a bit more stable. You could also install an oil cooler and likely use off the shelf oil, of course it would take quite a while to recoup the cost through cheaper oil. If you decide to go that route, I'd go with an oil-water unit, I've heard good things about the Laminova brand.
The copper perplexes me in the absence of an oil-cooler. Bronze bushings for the valve guides? I assume this engine doesn't have bronze small end bearings in the con rods. The low levels of Tin and Aluminum would seem to indicate the Copper is not coming from a bronze alloy though. Is there some other plumbing? Copper oil pickup tube possibly?
