Hi, here in sweden Auto RX arent common.
But i was thinking of using a bottle of redline motor oil
as a clean up additive in my normal oil.(syn 5-40 api sl)
I normally use a HDEO oil as top up oil abaut aquart in 500 miles
in my Mopar 5.9 v-8. The HDEO oil does do some solving inside as it quickly blackens the oil after it used. The outer route is to just use HDEO but its avail in only 15-40 and its cold here so..
By the way redline is expensive so i dont wanna use it as the lone oil..The engine has two uses a short commute (1-mile, with full power bursts if my fire pager sounds on a dead cold engine) and the other is towing my horses so it is not living in the easiest of worlds.
