Recommended oil for an old oil burning engine
Originally Posted By: toneydoc
If it is not burning too much and by that I mean more than a quart every 750-1000 miles or so, just keep using the 10w30 you are using. Oil is only $4 a quart or so. I doubt any oil is really going to slow down any burn caused by a ring or rings or seals.
Just make sure you check it regularly until you rebuild it. Keep it topped off to full mark and at least you know it has a good oil with good additives in it.
Good luck on the future rebuild
The best advice I have read on this post. You must have some idea how many miles/ quart. Just because it smokes some is no reason to tear down an engine.
Originally Posted By: A_Harman
I'm thinking Valvoline MaxLife 10w30. Give it some time to work.
Yup - at 200 miles a year, I'll bet in 4 or 5 years this problem will be solved. Talk about 1st world problems...
