What is the recommended floor jack size for sedans (i.e. Hyundai Sonata) and up to mid size SUV's (i.e. Hyundai Sorrento) ?
I believe they come in 1.5 ton , 2 ton and 3 ton version's . Also if there is a particular brand / model you believe is a best value also please advise .
*Main use of the floor jack will be to lift up the side of the vehicle to access transmission pan to perform ATF drain & fill function ... Thanks in advance for replies !
