It's a maximum value I guess. Would Mobil 1 Full Synthetic xW/40 be a good replacement for ILSAC certified oils? Even though it lacks ILSAC?I’d look for an older style add pack with a high TBN. What application/location? 500ppm is pretty high, is that a max spec or an actual measured valuation?
Thanks a lot. Euro specced oils are going to be a better fit for my application, but will I'll do more harm than good to bypass ILSAC specification for more TBN?Looking around the Egypt web site for Shell oil, you have a few options
Shell Helix HX8 5W40 synthetic is rated API SN (American) and ACEA A3/B4 (European) so that would have a high TBN (>10) due to its Euro rating.
Also Shell Helix Ultra 5W40 is SN and A3/B4, its called Pennzoil Platinum Euro in the USA.
From the Castrol Egypt web site, you have
Castrol Magnatec Dualock 10W40 which is SN and A3/B4, a semi-synthetic.
You also have Castrol Edge 5W40 SN and A3/B4 full synthetic.
Any of the 4 oils listed above would do me.
I'm assuming you are from Egypt, due to your details. It appears your market has a lot of conventional oils 15W50 or 20W50, that are only rated API SL. I would avoid these SL only rated oils.
quick answer: not with the oils recommended.Thanks a lot. Euro specced oils are going to be a better fit for my application, but will I'll do more harm than good to bypass ILSAC specification for more TBN?
I understand that specifications generally are just a game of managing different engine oil performance parameters. Yet, am I gonna lose something valuble an ACEA specced oil is short of offering ?
You will be fine with ACEA European spec oils, they are generally considered to be a higher quality standard than ILSAC oils. The ILSAC oils are focused on fuel economy, while the ACEA A3/B4 oils are focused on wear protection (high HTHS) and long life (high TBN).Thanks a lot. Euro specced oils are going to be a better fit for my application, but will I'll do more harm than good to bypass ILSAC specification for more TBN?
Mystery vehicle so he should use Mystery oil.What vehicle?
Lol!Mystery vehicle so he should use Mystery oil.
Actually I'm waiting for a HUGELY gained benefit from knowing the make and model that would affect this critical decision of choosing an oil that's no longer a mystery and something else the good guys above have not already mentioned.Mystery vehicle so he should use Mystery oil.
He has a little moped.
Just joking with you. But actually, the appropriate oils for high sulfur fuel might not be so good for an I'm just lost out trying to balance a two different demands at opposite direction. But I am just gonna stick
I just noticed thanks to you that FS xW/40 doesn't offer SN+/SP. Well, we need to balance out two polar demands of High TBN and LSPI problem. Do you think that FS xW/40 address LSPI as stated in the Mobil 1 website (suitable for turbocharged engines). Is that a guarantee like SN+?Just joking with you. But actually, the appropriate oils for high sulfur fuel might not be so good for an engine prone to LSPI. Hence, my curiosity.
I sort of thought I got this case closed and you just opened a door for another stream of over thinking , Lol
OP is in EgyptWhere do you get 500 ppm sulphur fuel? North America is 50 max,Europe and Australia are less I think.
While Mobil 1 FS 0W-40 is not a high mileage oil (not knowing what you consider "high mileage"), and relatively thin for a 40 weight given it's 12.9 cSt @ 100°C, it is useable. But I would not extend your oil changes, even with a TBN of 12.6. If you don't do a lot of idling, 10,000 km would be a relatively decent interval. If you do a lot of idling, then I would stick to 5,000 km tops.Lol!
It's a Mazda 3 2013, 2.3 Turbocharged. I decided to go for FS xW/40 given the high mileage, need for higher TBN and better overall wear additives package. The car runs perfectly fine though. I would like to keep it on the road for long and was looking for a better oil that suits my application better given the high Sulfur ppm in our gasoline.
