Originally Posted By: cadfaeltex
I knew my filter looked different. Wasn't sure if that was for R56 etc or what.
I ended up getting the BMW oil (ordered it before this last flurry of responses). But keep it going since I need to think about what oil to run in the future.
Why does something like Mobil 0w30 fall short of the recommendation?
In my wife's Acura I run Sustina 0w20; does Sustina 0w50 meet the need? A mix of the two?
In simple terms, Mobil 1 0W30 would be too thin. It is not ACEA A3/B3 oil, HTHS is I thin 3.0, and for example Castrol 0W30 has HTHS 3.58. Now HTHS (High-Temperature-High-Shear) is VERY important for turbo and supercharged cars. HTHS of minimum 3.5 is required for 90% of European cars (some Volvos and Ford's could go for example with that Mobil 1 0W30).
So for you application, like for mine, wether oil is 5W30,5W40, 0W30 or 0W40 is not important. What is important is that HTHS number. So if on bottle it says BMW LL-01 that means it is ACEA A3/B3 approved, although I heard that BMW oil has HTHS of 3.35, but obviously they think that is enough.
Why not 0W50? First, it is too thick (something like Red Line 5W40). The HTHS number is important there and if it is above 4.0, it is not necessary, and your MPG will suffer, and car will feel sluggish (for example I can feel difference between Mobil 1 0W40 and Castrol 0W30. With Castrol car always felt more readily to rev).
Bottom line, if it does not say BMW LL-01 on the back of the bottle, do not get it.
If you wanna be on the safe side and save money, get in Wal Mart Mobil 1 0W40 or Castrol 0W40. Both are $25 for 5 qt.
