Recommend me a Pressure Washer
Originally Posted By: Phishin
What you guys think of this unit?
GX200 + CAT Pump + 2.5GPM
But for a few hundred more:
3.0 GPM Unit
Is the higher volume, but lower pressure worth the extra money?
The first one is 3300 PSI at 2.5 GPM
The second one is 2500 PSI at 3.0 GPM
What do you think?
I do like the second unit lot a power for your needs quick connect hose 50 foot 3/8 hose other is 25 1/4 length matters tip size will dictate volume Thing would last a lifetime if taken care of.
Originally Posted By: dave123
I would spend a little more for better quality Honda GX with a Cat pump taken care of it last you a lifetime less headache in long run.
I have one of those, as well as a $100 Ryobi special, the ryobi gets more use...
I bought a Karcher with Honda GC 190 motor in 2009 - it's been excellent. I bought it end of season at Costco for $300 Canadian. It's not worth the money to get electric.
Just took a look at your link. That's an odd duck...never seen a PW used on a vert. shaft motor before. The design puts the pump quite close to the ground, where it's vulnerable. I'd return it while you still can.
Don't ever store the pump wet.
Never store with water but yes absolutely you can on anifreeze and should after every use and never left with plain water in it.
I used a gas model to clean my patio. Those things are powerful enough to damage brick & concrete, so be careful washing a driveway if there are small cracks or chips or any compromised areas. Oh, gas washers are very loud too
For the experts here: is a $150 electric model strong enough to clean 2nd story gutters using a 25-foot wand?
