I can't use the drill method to turn the pump over...this pump doesn't have that function. Does anyone have any suggestions?
Someone told me to maybe hook something up to the oil pressure switch hole or something and pump it from there. What is he talking about?
I also have access to a 2nd Drain Plug on the block itself (identical to the pan plug) but I don't know what it feeds, that isn't normally accessible when the engine is installed in the car. Can it be primed while on the stand through this hole also?
