This is a 1990 Amana unit that I have to top off with freon every few years. Started using it a few weeks ago and it runs nearly nonstop without cooling much. It's about 70°F coming out of the vents when the house is at 78 and outside is about 85. This is the before shot of the gauges,
and the pressure chart with this unit on the right side,
It took about an hour to add 3 pounds of R22 and this is what the gauges looked like then, better but not the 80/236 psi on the chart,
and the vent temperature,
Much better but shouldn't the pressures be a little higher and the vent temp a little lower, like in the 40's? Why won't it take more R22? Tired compressor?
