My SO has a 2013 Sienna LE. It has a slow freon leak of some kind which will need to be addressed professionally. What she usually notices is that in hotter conditions the driver's outlet air will warm up compared to passenger. A little top up (like every year or two) and it's back to running well.
In taking a look at it yesterday I observed something puzzling. My "common sense" would tell me that if you shut down the rear HVAC it should improve performance of the front AC (by which I mean vent temperatures, not cooling the air volume inside the car). Instead it has the opposite effect. It's quite hot/humid here right now. She had the rear system off, forgot, and a rear passenger asked if she could turn it on. The driver's side was struggling a little, which is something she was used to. She hit the button to turn on the rear which went full blast and almost immediately the driver's vent cooled off dramatically, despite all the extra load from the rear.
With a pressure gauge hooked up, I observed that when the rear is shut off, low side pressure dropped dramatically along with corresponding warming of the driver vents. What's going on? Lots of liquid refrigerant loading up in the rear evaporator due to no load, accentuating the low charge condition? Some kind of reduction in compressor output due to switching off 2/3 of the vehicle demand?
It was about 100F and humid outside. High fan setting, low pressure readings:
All on, normal idle, 45-50psi.
All on, 1500rpm, 35-40 psi
Rear off, 1500rpm, 20psi
My rough estimate gauge says low side should be 50-55psi in these temperatures, but I know it can be more complicated than that. I'm also not clear if the "guideline" low side pressure targets are at idle or raised from idle.
At any rate - I'm curious if anyone can explain why shedding heat load reduces performance in this undercharged system.
