Rear end rattle...what to check?
El Oeste
2007 Pacifica 4.0 Touring FWD has what can best be described as a bit of a rattle when going over a bump. Road cracks, manhole covers, etc. will produce the sound, but speed bumps and elevation change from street to driveway (over the rounded off curb) make it most noticeable. Seems to be coming from rear passenger side. One or two rattles and then it's back to quiet once back on level ground. Best guess is one of the self-leveling shocks has worn out, but I'm hoping for something else since those are $250 apiece. Bushings? Something else?
Not yet. Would that affect tire wear? (Everything wearing normally.) Also, this seems to have come on gradually over the last year or so.
Probably is the shocks, but you really need to get under there and try to wiggle some stuff around.
Shocks, sway bar links, busted spring pockets, and loose brake splash shields would be my main suspects.
Does it still rattle if you ride the brakes over a bump? If so, that would rule out any brake pieces (like pads rattling in the caliper brackets). If the rattle goes away, however, then you may need to service the rear pads.
+3 on the end links
I'm down for a +4.
When they went in my car, it sounded like a bowling ball rolling around in the trunk.
