rear diff viscosity/new Doge Cummins 3500
ohio
I just changed the diff fluid on my 3500 Dodge with Swepco 80w140. I now am told that AAM axles spec a 75w90...Will i be OK or do i need to chnage it out? The truck is used for trailer towing, approx 12,000 pounds. Does anyone know why AAM would spec a 75w90?
You will be fine. I would change it back though the next time it is due. The speced out a 90wt. for a reason.
Swepco makes a very good gear oil. If you change it again, use the Swepco 201.
Thanks guys! So you think I'll be OK running this for 15,000 miles? Next change I'll go back to 75w90.
I'm running 85w140 Royal Purple in my 04 ram...I've got almost 90k on it with nothing but good results.
So, I guess knowing more then the engineers is OK here.
If you plan on sticking with the 75w90, check around for improved cooling/capacity diff cover.
I changed after they issued an internal memo stating that 75w140 was recommended for towing...
I don't work for Dodge, so I don't have the memo.
When I started owt I couldn't even spel enjaneer...now I are one.
BTW, You can get a finned diff cover at Summit Racing
Most likely 1 of 2 possible reasons:
1. 2/3rds of the guys at AAM are idiots left over from GM
2. The bearings might not like the thicker viscosity. AAM has lots of diff carrier bearing issues because they discarded most of the proven designs of the past to make it "better" (cheaper).
