I have an '03, 3500 with that same axle. I've changed out the gear oil twice, now. At 15,000 miles, the stock gear oil looked kind of nasty. Gray in color with wear in debris, in it. The gray is from a lube they put on the gears at the factory. This gear oil change is a good idea & I wish I had done it sooner than the 15,000 miles, just to get the break-in materials out of the axle housing.
The second change was at a bit over 30,000 miles. That gear oil looked almost like brand new. In my opinion, that change was a waste of time & money. I used the Mopar product on the first gear oil change. Got the dealer down to $15.70/qt. They wanted $21.00/qt.
This last gear oil change, I used RedLine 70/90, at $7.00/qt.
The Mopar gear oil is a Texaco product that is re-labeled for Mopar. I called Texaco to see if it was an "off the shelf" oil. They would not say, probably because they do not want to jeopardize their relationship with Mopar. Mopar would like you to believe it is a "specially-made" product, just for Mopar. I called the local Texaco Rep. & he said that he did not think Texaco was making special oils, just relabeling their off the shelf products.
My guess is that the RedLine is a superior product.
If you check your manual I believe you will find that the recommendation is for a 70/90 gear oil, not specifically the Mopar 70/90, only, with a Mopar Part Number. Now, the NV-5600 stick shift does give you a Mopar part # that they recommend.
I also, called American Axle & asked about the 15,000 mile OCI's & they thought that was overkill except for the initial change.
I tow, a bit, with my truck & live in the desert SW with high heat & mountains. That's a lot harder on all your fluids.
Jim Allen,
Thanks for your excellent explanation of the AAM Axle's in the Dodge application. That would be very appreciated on the Turbo Diesel Register.com & Diesel Truck Resource.com websites. Please consider posting the information you have at these sites. Thank You.
Joe Fihn
