Real dual-purpose SUV
California
What would you do to an SUV to harden it for real dual purpose use and which one would you start with.
A friend has a V8 4Runner, lifted 3", some bigger gas shocks, xtra skid plates, brush bumpers, a snorkle system with a great big air cleaner, a larger 12 quart oil pan with baffels and a scraper. He has added air lockers front and rear with some big nobby tires. He started with a capable vehicle and has added to it without a lot of fuss. He has added a few small things like a cooler in the P/S line and a large spin on transmission fluid filter with a larger trans pan and the engine has a bypass filter, a Frantz and a Frantz adapted to the fuel system along with an extra water seperator and an extra inline fuel pump that can be switched on when needed. The cooling system has a filter in parallel with the heater core. His only problem is the brush scratches and dings from really going off road, not just posing.
I just wonder what you would do given a fresh start.
Popular down here is either a diesel Land Cruiser or Nissan Patrol.
Suspension lift coupled with a body lift. Big tyres. ARB Lockers. Winch. Dual tanks (250l combined capacity often). Aftermarket fuel filtration (increased availability of spares). Bull bar. Side rails (sometimes). Dual Batteries. Enough lights to start a paint baking booth. Couple of radio systems. GPS.
Winch is first. it is the only add on that will get you un stuck, everything else can just get you stuck worse.
After winch add what ever you think you will need for your area.
