JHZR2
Staff member
depending on where the oil was on the plug... on soome/most/all DOHC engines, there is a cylinder that is friction fit into the head, and has a rubbr seal on the valve cover side. Often these seals or just plain seepage from underneath will allow oil into the cylinder that has the spark plug at the bottom... (sorry for the poor explanation)
This can cause oil to come into the threads, dirty the boot of the spark plug wire, etc.m etc. Id imagine it could find its way all the way to the outer edge of the spark plug if it seeped all the way through the threaded section, or, you could have 'wet' the plug with oil when pulling it out.
Ive seen oil in the spark plug tube many times before, and it makes the plug look oily on the threads... no real harm done though...
JMH
JMH
