Ive done this a number of times, and clear is picky. The best formulation I found is the duplicolor wheel and rim paint in clear gloss. it usually sprays on with a bit of orange peel and then flows to smooth, but not always. The cans don’t always seem to be consistent. The duplicolor has been the highest strength I’ve used. Closely related is VHT, which I believe is from the same primary manufacturer. VHT cans have been more consistent.
I AM NOT A PRO, so this is just my own experience - several things affect clear…. Notably ambient temperature and paint temperature. the painted item needs to Not be hot, so the paint can settle and flow. Yet, I’ve found with VHT, it can help to warm the cans by letting them sit it hot water.
I think both brands are an acrylic enamel, and both need 7 days plus to fully cure…. They can be driven on in a day but they don’t seem to fully harden for 2 weeks.
I wouldn’t bother with krylon, rustoelum, etc.. The “lacquer” formulations (not true lacquer) have held up well for me on body panels and seem to interfere less with affecting the color, but it’s thin, very thin. Thus, I’ve not used it on wheels.
try wet-sanding your wheels now with a fine sandpaper and using a different product, if u are certain it’s fully cured. Note- any 5 foot paint job on wheels will pass all common viewing after 3 days of road dust.
