...well, I discovered this noise from distributor, like a modern injector noise. A continious but very subdued sound, you need to lean towards the cap with an ear to notice it. I guess there is an arc patern inside it. Previously I had started to feel something like a misfire at high speeds, so the flash striked and I think I really have a misfire problem. There used to be an occasional arc from a cable to the oil-stick tube, I solved it with better insulation to only move it to distributor
Runs very peppy at lower speeds. Cap is relatively new, inside is clean, no carbons. Dew? I sprayed wd40 many miles ago (could this be the problem?) I'm going to replace the spark plugs, wires, ignition module, the coil and will hope it to go away (eventhough many checks ok). So, to be frank, I don't know what is really going on. If there is any insights, or experiences I'd highly appreciate it.
