Rank these filters
Toronto Canada
Rank These filters...
  1. Mann
  2. Mahle
  3. Baldwin
  4. Baldwin
  5. Bosch
1 and 2 can switch if you want, 3 and 4 are basically the same.
Why, well, why not.
I would use any of them if they fit.
If I had to pay retail for them, then none, I would probably use something else.
Of the one's shown Bosch seems to have filtration efficiency available, and is good.
99% @ 20 micron
Why is it so low on others list?
I could find one of the Baldwin was 18micron Nominal; 40micron Absolute
Could not find any info on the others.
In terms of efficiency, The Wix is inferior to a Fram.
Gonna have to be more specific. Are you referring to an XP? Then yes, those are trash. I assume you're also referring to an Ultra? That's the only FRAM that has my respect, but based on one lone experience with one I won't use another unless I don't have a WIX/NAPA Gold option when one is needed. It made the valvetrain pretty noisy. Maybe it was a defective filter, maybe it was coincidence, but when I switched back to a WIX it disappeared.
Bosch is made by Purolator, and Purolator will always be on the bottom of my lists.
I know the Bosch is made by purolator but it is one of their better filter designs. I know purolator has a bad reputation on here since tears were discovered in the media. I've used a lot of these filters w/o any issues. No - I did not cut them all open, just 3 and they looked fine. I still buy them when rockauto has a good deal at about $3 and I'm happy. I also like the Mann filters atleast until ownership changed. Other than that - I agree overall with your ranking.
Mann & Mahle German made? Pretty good, but some Mann ones are made in the Purolator factory, as is the Bosch-which means "caveat emptor"! I've never heard anything bad about Baldwin, and every one I've used has been fine (although efficiency is a little low).
