A few years back, my Element's radiator started leaking, It would slightly drip and I could smell the coolant burning off.
It was replaced by a local indy with an aftermarket radiator (I was in a rush to get it done before a trip, so I didn't do it myself). About 3 months later, it started to do the same thing. It was replaced under warranty. A few months after that, I started noticing the smell again. I figured I had a bad run of parts from that vendor, and since I had more time on my hands, I bought an OEM radiator from Honda and did the installation myself. I figured I would be more careful. Fast forward a few more months, I smell the coolant again.
I have a pressure tester on the way to isolate the leak, but I can see the dried blue-green coolant along the top of the radiator, where the plastic endcaps meet the fins. Each time, the reservoir was drained dry. I believe the fluid was properly flowing out the cap when under pressure and sucking back in when cooling down. The hoses are all original as the indy said that they were in good shape when they squeezed them.
I'll keep you guys updated as I run the pressure test, but just wanted to see if you guys had any initial thoughts on what to check.
Thanks!
Thanks!
