Hey all, this is a GREAT forum. Proof that the internet is good for something other than celebrity news and porn (which can be the same things...)
Anyway, I need some advice to optimize my racing efforts...perhaps you all can help me.
I race a 1990 Mazda Miata in what is called SpecMiata. It is based closely on production parts to keep the cost down. For example, the motor must be STOCK, as well as the tranny. I use a junkyard motor with like 80K on it. We do mostly longer endurance races...1,2,6, hours etc.
I race mostly in the NE and MidAtlantic so the abmient temp is very variable.
I am currently running Valvoline VR1 20W50 and changing it every 4 hours of use. I am using Mazda factory or Bosch oil filters and Redline MTL in the gear box. This all seems to be working fairly well.
Given the above...
1. What would you recommend for an oil filter. Given that the motor is fairly well broken in, and that the service life of the oil is reasonably short, I think something with decent filtering capablities and low restriction would be good. Because of the nature of racing, the oil gets around 200 and about 35-50 psi. Are my assumptions correct? Any recommendations?
2. What brand of oils will work. I am looking for something that can run hard for 12h or so for some events, and something that is better suited for the shorter stuff...1-4 hours. They don't have to be the same.
3. Is the new Green company airfilter any better than the K&N or stock filter. I've heard that K&N isn't THAT much better than stock, but I'll take any advantage I can get.
4. What would you recommend for gear box oil? I haven't had any problems with Redline, but I've heard good things about Royal Purple, Mobil1. I don't change it that often, perhaps after 30h of use.
That's all I can think of now...thanks SO MUCH, this forum and you all are great, I've learned a ton so far.
Eric
NER SSM #12
specmiata.com
[ March 19, 2004, 03:12 PM: Message edited by: rugerman1 ]
Given the above...
Eric
NER SSM #12
specmiata.com
