Has anyone have any experience using Mobil 1 Racing in 0w-30 for endurance road racing? I have a Honda K24 that does endurance racing at 8 hours event. I'm planning to use Mobil 1 Racing 0w-30 as it has high amount of zddp and Phosphorus for engine protection. I will most likely change out the oil after an weekend of 2 days of 8 hours endurance racing or i can sent it for lab report in hoping to use for an additional weekend. I think 30wt is bit thin for endurance racing but Mobil 1 don't come in 40wt which would be great. However, they do come in 0w-50. Maybe I can mix both for 40wt?
Please let me know if anyone have any experience on this oil for endurance or road racing? Any other recommendations?
Also don't forget that anti-wear additives are just pieces of the puzzle. The end product, the overall picture, is what truly matters. And M1 0W-40 definitely shown itself as a good performer in high demand applications. It does drop to a "heavy" 30-grade quick, but stays there for the long run without sacrificing engine protection. May help yield another horsepower or two? Here is an older Q&A from Mobil about their ZDDP content, with another user. If, however, the hot oil pressure is too low with M1 FS 0W-40 for your liking, then Mobil 1 15W-50 is another great option. High levels of Zinc and Phosphorus as well, even higher than M1 FS 0W-40.
Question
“For an older, flat tappet, performance motor with inherent cam wear issues is there any benefit to mixing high ZDDP Mobil 1 Racing™ 4T 10W-40 to Mobil 1™ High Mileage 0W-30 oil? The 15W-50 creates TOO MUCH oil pressure. It would be nice if you had a product for 'Classic' cars, high ZDDP, 0W-30 and 0W-40. I have used nothing but Mobil 1™ oil for 15+ years.”
Bill McCauley, Tallmadge, Ohio
Answer
Mobil 1™ FS 0W-40 oil already contains a higher level of ZDDP (1,000 ppm) that could benefit your flat tappet engine. We also have a
Mobil 1™ High Mileage 10W-40 (1,000 ppm); see the
Mobil 1™ Product Guide listing the phosphorous levels for all Mobil 1™ synthetic motor oils.
