R134A can tap problems / suggestions for new?
Lowcountry South Carolina
I have this can tap. Bought it on Amazon.
Today I had it not open a can. Think its the can, or is it this tool? This time it wouldn't seem puncture the can at all.
Last time it punctured a small amount but not enough to fill the car.
So thats 6 successful punctures and 2 fails.
The gasket is now pooched, but it wasn't before. I overtightened it trying to get it to work likely.
Is this tap NFG? Or just bad cans? Suggestion on where to buy a better can tap?
This is the can it would not open. I believe this is the new style self sealing correct?
That photo you posted certainly looks like the new style self-sealing valve on the R-134a cans. In my experience, the self-sealing can is sensitive to how deep the valve tip depresses the valve. On ~20% of my cans, the refrigerant won't dispense correctly (or at all) if the plunger rod is fully turned down until it stops. I have to back it off ~1/2 to 1 whole turn on some cans for the valve to fully open.
Exactly what I use for 1000's of cans before I bought my machine.
I don't use mine as much as I used to because I have 30 lb tanks of refrigerant and use a refrigerant scale to put the tanks on so it's a lot easier, faster, and more accurate than using cans.
What brand(s) of R134a were you having trouble with...
I think that is part of the problem. The SuperTech R134a can's with the new style top don't seem to work as good or maybe require a different can tap.
Link to the actual tap you are using.
My recommended can tap:
https://mastercool.com/product/r134a-1-2-acme-m-self-sealing-design-can-tap-valve/
Yes, it's more expensive:
https://www.amazon.com/MASTERCOOL-134A-Depressor-Style-Can/dp/B07V9XFB6H/
One complaint in the review was about the SuperTech cans though. It's the cans, not the tap.
Thank you for the link. I actually was looking at that one. Buy once cry once.
The first can I had issues with last fall was Supertech R134A. Once pressed it not only didn't work but leaked out slowly.
The current problem child is Chemours - from Autozone. It isn't leaking just not working at all.
