Hi All,
I'm looking to build a supplementary gas-powered air compressor.
I have a small 24 litre 1.5HP compressor which puts out ~6.5cfm. It's enough to run an impact for a few seconds, small air brushing, pumping up tyres etc etc. However, sometimes when using the impact for repeated tough bolts or spraying stonechip/underseal etc it is running constantly and can't keep up.
I have acquired 3x 15KG Butane bottles which I have purged with water loaded with Bilt Hamber Atom-Mac to stop any corrosion and planning on mounting them upside down in a rack at the back of my shed which is at the end of my garden to increase my air storage capacity. It'll be burying a 1/2" air hose in a duct up to my garage where it will T into the existing pipework in my garage. They'll be guarded with mesh and ply-wood to ensure some protection if one does split or break.
I've also acquired an old air compressor pump. It's 4hp/18cfm and needs to spin at ~1500rpm. While perfectly do-able with an electric motor and easier being that I'm an electrician, I have a love for engines and would love to run this with a small OPE engine.
I need the engine to be reasonably quiet because when I'm spraying or using grinders etc I can be using them all day. I've seen devices that will operate the throttle/governor to reduce the engine speed once the system is up to pressure which I plan on using.
BUT... is there any truly quiet 5-6.5hp OPE engines out there? Or am I better off buying a cheap Chineese copy and investing in some sound deadening? Maybe boxing it in (providing it with adequate airflow of course) with some sound deadening foam/egg crates?
