Developed a squeak while depressing on the clutch pedal. Never tried applying lubrication before so I wanted some pointers.
I am hoping to not need to disassemble anything. I believe I can get access from under the car.
1. Where the slave cylinder pushes the fork, can I push the slave cylinder rod inwards to create space so I can put some silicone grease on the ball? or I should push the fork instead?
2. There's another pivot ball with the fork under the dust boot, is it possible to pop off the dust boot without taking off the slave cylinder to gain access?
3. Should I try to get silicone grease applied in that area or use white lithium spray can? I feel it's quite tight to get in there and wonder if that part needs greasing or not?
