From what I'm reading, what moly does is provide a protective layer on metal surface creating a smooth barrier like in cylinder walls. Would this be considered a anti wear additive? like zddp.
Also moly is a metal mined. What process is used to put it in a lubricant? I guess there are different types of moly, the one in the lubricant would be considered mos2?
Last question. Is moly overkill? I see only some oils contain it. But some do not.
