- Joined
- Dec 30, 2006
- Messages
- 29,558
M1 15W50 :^)
A_Harman said:(This is why I was recommending the Redline 5w40. It has equivalent High-temperature, High-shear viscosity to 50-weights, but has kinematic viscosities of 40-weights.)
Not good advise IMO.
Red line is not an authorized Mercedes lubricant. Furthermore, RL 5W-40 with it's HTHS vis of 4.6cP is even more viscose than M1 5W-50,(HTHS vis 4.21cP) let alone the 3.8cP of M1 0W-40 and the KV100 spec' is of no consiquence.
SnogardE55AMG said:Here's another example. Castrol TWS 10w-60 works great in a newer M3, but in my car it would be far too thick because my car doesn't heat its oil up enough. My car prefers xw-30 and xw-40 oils, which would be too thin for a newer M3 because its oil temperatures are higher.
It would be more accurate to say newer M3's "may see" higher oil temp's. The reality is, even most street driven BMW's for which the TWS is specified still don't see higher oil temp's. This actually supports your main point of not needing to run a heavier oil even with higher performance engines.
Originally Posted By: d00df00d
(remember also that the Porsche Carrera GT, Porsche 911 GT2 RS, and Corvette ZR1, all of which have well over 600 HP, also use Mobil 1 0w-40)
If I'm not mistaken the spec' oil for the Corvette ZR-1 is M1 5w30, the same oil as for the normally aspirated Corvettes.
The point being, that the Carrera GT and GT2 share the same oil that is used with their less powerful stable mates.
