Originally Posted By: 6starprez
Originally Posted By: MoreCowbellAz
I never thought about a regulator, am I correct that it would reduce the output through the blow gun to be only what I need and thereby prolonging my air supply? Or maybe that's overkill.
Wait a minute, you said "tank" as in portable tank? I thought you were talking compressor. I don't know if you could put a regulator on that
Sure you can. Just go buy one and thread it on and then leak check...
OP, the thing with a regulator is this - lets say you really only need 40 psi air to blow out your jobs. If you fill the tank, either main and/or supplemental to, say, 135psi, the first air that comes out of the gun is at 135 psi. Then what comes out is consistent with tank pressure. So youre wasting air to start, and then using really low air later on. If you used a regulator, you would get consistent 40 psi air until the tank pressure went below that. This would provide better, more efficient use of your stored air when the tank is at high pressure.
This can be observed, if not calculated, via the Hagen–Poiseuille equation, and/or the Darcy–Weisbach equation. Essentially, these relate pressure with flow (with a variety of other factors like viscosity, pipe diameter, etc.
So the flow with Pin=40psi and Pexit=0pis is different than the flow with Pin=135psi and Pexit=0psi, if you observe the equations.
What that shows is that if you regulate down the pressure, youll waste less at the start. For the sake of argument, lets say your tank has 10 atmospheres of pressure. per my post above, one cubic foot is like 7 gallons, but to make the math easy, lets say you have one cubic foot of air in the tank... at one atmosphere.
Then you really have ten cubic feet of air in the tank if it is at 10 atmospheres. Assuming you slowly bled the quantity of air out at atmospheric pressure.
What limits you is the outlet pressure, you can only really access with the blow gun the delta in pressure between the tank max, and what you need the regulator to provide.
But regulating it, despite the regulator's intrinsic losses, will maximize your usage, especially if you add a supplemental tank...
