California Air Tools anyone?
Talkeetna AK
I just ordered this for some basic stuff like future brad nailing, tire pressure, blowing out dirt, etc.
California Air Tools CAT-2010A 1.0HP 2 Gallon Ultra Quiet Aluminum Tank Air Compresso
Not sure if I will ever uses any air tools. Cordless drill/driver works well for me in mist apps.
Just curious if you have had any experience with them?
Again, I already ordered based on reviews etc so it's a mute point. Just curious.
https://www.walmart.com/ip/California-Ai...13=&veh=sem
Originally Posted By: Chris142
Never heard of them. But it seems like a lot of that kind of stuff comes from the same factory in china. Just different stickers.
I think they are made in California with some Chinese parts.
I would have to double check that though.
Their claim to fame is that they are VERY quiet.
I run a California Air Tools compressor, specifically because it is very quiet. I have a 4.6 gallon aluminum twin tank model. It works great. I did have one of the air pressure gauges crack at the fitting. They were pretty quick about sending a replacement part under warranty. Lot of Chinese parts on it, as expected. I use it for airing tires and pin/brad/finish nailing.
Correction, made in China. Company originated in California.
Ya probably moved out of the state due to the huge regs Calif puts on small businesses.
I just bought one of their small compressors. Very quiet and fills tank quickly. Very impressed.
Originally Posted By: ted s
how big of compressor do i need to use an impact to remove lug nts?
Take a look at the specs of the impact wrench, it hsould have a CFM rating that should give you a rough idea of how powerful of a compressor you'll need. A smaller compressor will probably work, but you'll be waiting a bit while the compressor kicks back on and catches up. In general though, get the biggest one you can afford and can fit in your shop
