I don't believe so.
Assuming the filter media is the same more pleats = more filter area = longer life.
That would be my guess also. More surface area (of the media) shoved into that area means it can be used for a longer time.
If I may add a little info that you may find interesting. Your engine "meters" the amount of gas based on the volume of air.
As your filter gets more clogged, it will compensate for the more restricted air flow volume by reducing the amount of gasoline.
Your car's computer is constantly maintaining the proper air/fuel ratio.
I used to think that as my air filter got more clogged over time that it would hurt my gas mileage. I have now been
taught that is not the case as my car's computer will simply reduce the amount of gasoline being injected into the cylinders.
It may hurt performance, I guess???
True. What happens as the filter clogs up is that the throttle valve is simply opened up more when more power is required. The extra drag of the clogged air filter is simply countered by opening the throttle more. Until one hits WOT then nothing is noticed. Until WOT the engine is being choked from full power output, and it doesn't matter if it's a throttle valve or something else restricting airflow.
In ye olden days it was different, the extra throttle opening might cause the carb to change from idle circuits to high speed circuits, and the extra vacuum signal might play with things... been too long since I understood how those worked, but they did use vacuum and were very mechanical in nature, and altering the system would alter the mechanisms at work. EFI just doesn't care (until WOT).
