Direct from SOPUS tech support:
Quote
The answer to your first question is that Pennzoil Platinum is one of the leading Synthetic oil in the market. At this time we are waiting for the data from the comparisons to other Synthetic oils.
Next, most engine lubricating oils today are made from paraffinic crude oil. Paraffinic crude oil is recognized for its ability to resist thinning and thickening with temperature, as well as its lubricating properties and resistance to oxidation (sludge-forming tendencies). In the refining process, the paraffinic crude oil is broken down into many different products. One of the products is wax, and others are gasoline, kerosene, lubricating oils, asphalt, etc. Virtually every oil company uses paraffinic base stocks in blending its conventional engine oil products.
Many people believe the term paraffinic to be synonymous with wax. Some have the misconception that paraffinic oils will coat the engine with a wax film that can result in engine deposits. This is not true. The confusion exists because paraffinic molecules can form wax crystals at low temperatures. In lubricating oils, this wax is removed in a refining process called de-waxing. Wax is a premium product obtained from crude oil, and to help us produce the highest-quality base stocks available.
We use base stocks with the minimum amount of wax possible. The end result is a motor oil product formulated with premium lubricating base oil. Then as for you maintenance schedule, it should be done to the manufacture specifications. Lastly, Shell purchased Pennzoil/Quaker State about 6 yrs ago and keep the product lines. Should you desire to speak with a technical representative to discuss this issue in more detail please call Pennzoil-Quaker State Technical Information at 1-800-458-4998
End quote
The above is in response to my question to SOPUS about paraffin in motor oils. Hope that answers your questions.
Cordially,
RicD
