QS green bottle vs PYB
Originally Posted By: aquariuscsm
Originally Posted By: OceanDoctor
IDK that is interesting though. It smells quite like asphalt TBH. Maybe the human olfactory sense is just *really* sensitive to sulfur
That`s definitely the way both Quaker State and Pennzoil Conventional smell. I bet it`s the same oil in both bottles. It`s also the same color too.
How can that be if they have a totally different smell? Something is different somewhere.
I recently chose Quaker State Advanced Durability over Pennzoil Conventional 5w20, b/c of the slightly better cold-cranking specs for Quaker State Advanced Durability over PYB:
Quaker State Advanced Durability: 4730ccs@-30
PYB: 5100ccs@-30
Price was pretty well the same, so I literally used this tiny difference to justify the Quaker State Advanced Durability, LOL. Engine runs smooth and fine so far!
Originally Posted By: 2010_FX4
According to tests performed in February 2010 by PQIA, there is only very slightly less sulfur in PPM in Pennzoil Conventional (3901) versus Quaker State Advanced Durability (4053).
Perhaps SOPUS changed the formula in Quaker State Advanced Durability?
Well according to the latest 5W30 Tests:
Pennzoil - 1845 ppm
Quaker State - 3315 ppm
http://www.pqiamerica.com/testresultssep2011.html
Im thinking the PZ is an Isomerate Base and the QS is Hydroprocessed.
Pennzoil - 1845 ppm
Could someone enlighten me on the effect of sulfur in motor oils? Is it for emissions? Better detergency?
Pennzoil - 1845 ppm
I believe it primarily comes along with the base stock in motor oil. The sulfur level in a base stock can be effected by the initial feedstock, amount and type of processing. Some additives also contain sulfur. Especially additives used in gear oils.
In motor oils, most of the sulfur comes from the additives, specifically sulfonate detergents and ZDDP. Group I base oils have a small amount of sulfur, but Group II and IIIs have very little if any.
Tom NJ
I will keep using Pennzoil conventional as in my area its $15.50 currently at Walmart.
Here in Houston at Wally Pennzoil Conventional is $14, Quaker State Conventional is $13.75, and Mobil Super 5000 is $13.97. My money goes to Houston based SOPUS and Pennzoil Conventional.
