Went to wash a load of dishes recently and upon turning on the power, all I heard was a seized motor! Brrrrrrrr......so I quickly shut it off. Never heard this in the 26 yrs I've owned this Maytag Jetclean DWU6502AAE.
Dirty dishes in racks went on the porch and I began to disassemble the innards. Found a small piece of rubber band inside the pump impeller and that was it. I don't understand HOW it got through the tiny filter screen. Another mystery is how garlic skins are able to get into the water stream and clog up the jets in the spray arms...both upper & lower. How does that happen?
I cleaned out the spray arm clogs, the motor was fine, no leaks underneath. Still not sure what would cause it to stall like that. Any ideas?
Something is still odd though as the two loads I've washed since the repair have had a few dirty dishes remain. Never used to see that.
I had some left over acoustical damping pad from another project, so I used it on the inner door surface. Now I can barely hear the water swishing around inside.
Any old-school Maytag guys here?
