PYB still a BITOG fave?
Originally Posted By: NASTI
Seems like Castrol Magnatec is the new BITOG favorite now.
Just don't get it. No doubt that it's a good oil and it will get the job done. BUT,
Apparently there is no moly, no sodium, no titanium, and little to no boron, and few of UOA/VOAs. It definitely has weak anti-wear additive pack, at least this is what we have seen from used oil analysis so far. Just don't understand what makes Magnatec special for some BITOG'ers.
If someone needs a conventional, Pennzoil Conventional is cheaper and it has good amount of moly in it, along with several good used oil analysis. Or if we are talking about semi synthetics, Valvoline MaxLife is as good as Magnatec, if not better. Also, it is cheaper.
Again, analysis reports don't tell us everything about a oil. Lots of good oils have no moly or boron. Technology is producing better components.
Thanks for the input. I am aware that lots of good oils which have no moly or boron have sodium as an anti-wear additive, like Valvoline. But Magnatec has none of them. This oil (Semi syn Magnatec) has been on the market for 10+ years in Europe, and I used it in the past. Now it is in North America, and just don't understand why it is so special for some BITOGers.
Although there are some additives that we are not able to see in the oil analysis, I highly doubt they use it in their entry level product. They still use Titanium and Boron in their top tier synthetic, and we are able to see it in analysis reports.
Again, it has a API SN and Dexos approvals. Not saying it is a bad oil, it will get the job done, but there is nothing "magical" in it at all (except their marketing
). There are some reasonably priced (even cheaper) synthetic blends with the same/more approvals out there.
My Honda ran on Pennzoil Conventional and Pennzoil High Mileage for over 100k miles until I switched to synthetic.
If I could find Pennzoil conventional for 2$ a quart I would grab it. I like it over most synthetics but it is hard to justify when it sells for 3$ a quart and supertech Full Synthetic can be had cheaper....
Have you tried the rebate?
Pennzoil Conventional is still a very good cleaning conventional oil. Seems like Castrol Magnatec is the new BITOG favorite now.
Not Here!
If you were running Pennzoil Conventional and Pennzoil High Mileage, then odds are very good you were already running at least some synthetic in that engine.
I'd say it's still a fan favorite here regarding conventional oils. Based on the searching/googling results that always came up on here when searching Pennzoil conventional vs Castrol GTX or Pennzoil conventional vs Valvoline conventional etc along with high mileage formulations. Almost always to be more Pennozoil recommendations. Seems like people prefer the Moly/Boron add packs over the add packs that show up as mainly sodium based in VOA/UOA "SDDC" or Mobil Super 5000 in GF-5 targets. In the end I think you will be good if you pick an oil that meets the manufacturers specifications. If you like Pennzoil go with it. A lot of those threads are old and was before the rise of the Direct Injection turbo engines. I've moved over to full synthetic in my Direct Injection turbo engine. Pennzoil Conventional or Castrol GTX might get to 5k but don't care to risk it. Feel better running Pennzoil Platinum / Pennzoil Ultra, Edge, or Magnatec.
