After checking out Gary Allen's new test, I'm not so sure that any filter actually restricts the flow of oil (well, up to a point). The oil pump is a positive displacment pump, so if it's in correct working order, it'll pump the same amount of oil through the filter regardless UNLESS or until the pump bypass opens. I'd be the filter would reach it's PSID and the bypass would open before there was enough restriction/total system pressure to force the pump bypass open. So the filter may bypass just a little on cold starts, but once the oil temp comes up, it probably rarely bypasses.
