Well, at least some Purolator branded oil filters have the bypass valve mounted at the top - and I've seen that even on PureONEs. I can't vouch for all models, though. WIX seems to consistently place the bypass valves at the baseplate. At least some non-factory installed Motorcraft oil filters are actually manufactured by Purolator - and they have bypass valves at the baseplate, so Purolator is well aware of and is capable of manufacturing that technology. If you see a coil spring near the threaded baseplate with a rubber gasket sealing the filter, proper, from a spring-loaded plate, the design's a baseplate oriented bypass valve. A top-mounted bypass valve will have a u-shaped cap enclosing the spring for the bypass valve spot-welded to the dome end of the oil filter or a clicker type bypass valve identified with a series of concentrically arranged "holes" punched through the metal endcap covering a metal disc on the other side - barely visible if you study the view through the threaded mounting hole in the right light.
(Someone would have to prove to me that the location and type of bypass valve is really of vital concern - and I'm a hard sell. I believe it was Ford who started the baseplate location rolling in the '60s, but Chrysler, the Japanese, the Koreans, and the Europeans who still install spin-on oil filters don't seem to be totally sold on that approach. Are they really all morons?)
[ March 07, 2006, 05:22 AM: Message edited by: Ray H ]
